Use the following procedure to display the Intermediate-System-to-Intermediate-System (IS-IS) logical interfaces configured on the switch.
  1. To enter User EXEC mode, log on to the switch.
  2. Display the IS-IS logical interface:
    show isis logical-interface [name]
Example of a Layer 2 Core:
Switch:1>show isis logical-interface
                                             ISIS Logical Interfaces
IFIDX NAME     ENCAP      L2_INFO      VIDS      TUNNEL   L3_TUNNEL_NEXT_HOP_INFO  BFD      TUNNEL   ORIGIN  ISIS  SDWAN
               TYPE       PORT/MLT   (PRIMARY)   DEST-IP  PORT/MLT   VLAN   VRF    STATUS   SRC-IP           MTU   OPER STATE
1     SD-WAN-1 IP          --        --          192.0.2.3 Port1/44  4047   sd-wan disabled 192.0.2.1 ZTF    1400  UP
2     --       L2-P2P-VID  Port2/1   101,201(101)    --      --        --    --    disabled   --      config       N/A
3     --       L2-P2P-VID  Port1/3   102,202(102)    --      --        --    --    disabled   --      config       N/A
3 out of 3 Total Num of Logical ISIS interfaces
Example of a Layer 3 Core:
2 SPBoIP_T1      IP     --      --       192.0.2.15   Port1/25    500    vrf23        disabled  192.0.2.16 CONFIG  1000  N/A
3 SPBoIP_T2      IP     --      --       192.0.2.224  MLT10       2      vrf24        disabled  192.0.2.22 CONFIG  1600  N/A
4 Virtual-link-4 IP     --      --       4.4.4.4      PortRX-NNI  4051   GlobalRouter disabled  2.2.2.2    CONFIG  1600  N/A
5 Virtual-link-5 IP     --      --       5.5.5.5      Null        0      GlobalRouter disabled  2.2.2.2    CONFIG  1600  N/A
5 out of 5 Total Num of Logical ISIS interfaces
The command show isis logical-interface truncates the IS-IS logical interface name to the first 16 characters. To view the entire name (up to a maximum of 64 characters), use the command show isis logical-interface name.
Switch:1>show isis logical-interface name
 			ISIS Logical Interface name
ID     NAME
1      SD-WAN-1
2      SPBoIP_T1
3      SPBoIP_T2
4      Virtual-link-4
5      Virtual-link-5
4 out of 4 Total Num of Logical ISIS interfaces
The following table defines parameters for the show isis logical-interface command.
Variable
Value
name
Displays the full name of the IS-IS logical interface (up to a maximum of 64 characters).
